Once Again , I Need Some Advice/help
viperroom_112
In a moment of madness I purchased a bee sting aerial from www.ebay.co.uk . Unfortunately the piece of crap rusted on . After about three weeks of messing about I managed to get the aerial off and now I am left with a small screw in stump , that has also rusted . :( . :help: . NOw i have attempted to remove this aerial with wd40+pliars. and now an allen key and still no luck ? ? Any ideas
David
Mole grips?
You know you can unscrew the "tilty bit" and maybe secure it in a padded vice (carefully) so you can get a bit more purhse than when you're reching over the car.
:thumbsup:
A
excellant i didnt realise u could unscrew the tilty bit ! i shall attempt to fix that tomoro morning .... cheers alan
david
I had the same problem ....... I solved it by putting the aeiral back on and wiggling it side to side quite hard and then got some pliars on the aerial :thumbsup:
