Hid Bulbs For P1 Yaris
YarisGLS
I am thinking of getting H4 bi-xenon for my P1 Yaris, I wonder if any of you guys who did the conversion experience problems with the original bulb cover getting in the HID bulb's way?
The type I am getting will have a metal dome cover over the HID bulb, and a short length of plastic bit sticking out from the back of the HID bulb (the Hi/Lo mechanism), as you can see in the pic:
Will the short bit at the end of the HID bulb get in the way for the passenger headlight seeing there's so little space behind there?
Thanks for helping!
ill tell u on saturday mate when i fit mine :thumbsup:
Thanks mate! :thumbsup:
BTW, are you fitting the same type of HID as I have shown above? Or are you fitting the ones without bulb cover?
ok fitted mine today. the bulbs fitted no problem once they were in. but on the passenger side i did have to remove the fuse box which is only held in by 2 bolts to get easier access
here is them fitted and the difference they make
normal beam
hi beam
this one doesnt look too good. they look alot better when ur driving
