1997 Camry 3.0 Exhaust Repair
have a leak on the joint between the middle section and the rear section on the above.
Have been quoted £500 for Mild steel and £1000 for stainless steel replacement.
Currently using wynns gasket product to seal BUT can anyone suggest an alternative method or kit.
I was considering asking a garage to cut out the joint and then use some sleeving to fix, but all the rapid fit outfits just want to replace !!!!!
What a suprise !!!
The pipes are stainless but the flanges are mild steel, they are the items which have corroded.
Any bright ideas out there please ??
Stan
You'd be better off at a local garage rather than an exhaust centre, they'll be more likely to do the repair for you.
Or why not try finding a company locally that builds s/s systems, they'll do the repair for you no problem.
