Turbo Gauge
st dennis lad
im sure our resident 185 chappie (daktari) will be along soon to help you but with it being the X-mas period its been a bit quiet round these parts...
It's always quiet round my parts nowadays. :crybaby::laughing:
OK. Boost gauge. Couple of ways to connect but the best is probably the most awkward. :!Removed!:
This is the way i did mine. Down the back of the inlet manifold there's a sealed off stub (either 6 or 8mm) You'll have to grope around to find it. iirc it,s just left of centre about a foot down. It's got a rubber blanking plug over it secured with a spring clip. Remove this plug and fit appropriate sized pipe. You may need a reducer from this to whatever size the piping is for your boost gauge. Once you've done that just feed the pipe through to the interior using the wiring harness grommet on the passenger side of the bulkhead. There are a few other places you can feed it through but this was easiest for me. :yes:
HTH. :thumbsup:
