Tailgate Issues
SeanH
Okay, my rear wiper, the rear washer, and the rear window have all stopped working.
Surely these don't all share the same fuse?
Any ideas folks?
Oh! It's a KZN-185 by the way :rolleyes:
Any ideas folks?
Hi Sean
Make sure your rear window is fully UP as this will stop all activity with the rear wash/wipe system
I had this problem,spent hours checking thru fuses,wiring etc etc then by pure chance i needed to lower the rear window. when fully closed again everything worked OK.
Hope this helps you
Cheers
Paul
No, the window is screwed too!
It's been almost five months, and I've still not sorted this out!!
I reckon the curtains will be fitted before the rear electrics are fixed :bag:
Hi mate, just had my rear window (key or switch) stop working and wiper stop working.
It had been working fine 5 mins before and all I'd done different was fiddle with the wiper blade cos it wasn't parking properly.
Removed the wiper arm again and relocated it and now all works fine.
Worth a play for 5 minutes I reckon
Nige
  • 2 months later...
So did you fix it then????
Let us all know what the problem was so that if WE get the same prob this post may actually help!!???!!
