Wheel Arch Rubbing
EURO
Right ok i love my Yaris ts but ive found a problem with the suspension. Hopefully someone else will have experienced this as well otherwise theres something wrong with me front struts.
When i was coming home last week i decided to give the car a wee boot :ph34r: , now upon tearing into the corner which was a long hairpin i had my windows down as it was roasting when i heard a rubbing noise i thought i was just hearing things until i decided to tear into another corner just to see if i was imagining things but then again i was getting rubbing to the offside this time.
Is the ts suspension pretty soft coz its pretty hairy hearing the noise :eek: .
Lowering should stop body roll i hope but this was something that i thought i should share
any others experiencing similar let me know cheers :D
it might be the plastic at the front rubing..
the bumper protecter thing..
Sounds about right, especially if your setup is standard (e.g. Standard suspension and alloys)
Bodykit?
Takes a LOT to make a standard sus/wheel setup to rub usually.
if you have aftermarket wheels/tyres, it may be rubbing on a bolthead that holds the plastic fender liner in your wheel well
yeah i had that problem so i swapped the bolt.
but it still catches the metal every know and the
n
and thats dropped 30mm on 17's
I also have removed the bolt from front wheel and have replaced with a small screw. Looks a lot better that having a big old ugly bolt on show :D
jerry!!
cheers ill do that im still going to stick it into oyota though as the car is as standard at the moment so id like their official opinion
Yes i would mate. It's alway good to here what the pro's have got to say. :yes:
jerry!!
yeah a standard motor shouldnt scrub on standard wheels :huh:
I cut mine with an angle grinder :thumbsup:  :P  :P
Brave man you are scott :thumbsup:
jerry!!
