Fitting Yaris Wing Mirrors
bobhopkins
You have to take door trim off then unbolt 3 bolts! 2 are visable when black triangle above door card is removed but last one needs door card removing!
Be carful you dont loose lower nut becuase i nearly dropped it down behind door and tht would not have been good!
Someone snapped my drivers wing mirror off,how easy is it to fit a replacement.
Do i have to take door trim off.
There are 2 plastic screws on the door trim itself a screw in the small grab handle and one through the door handle itself, then pop off the electric window swithches and disconnect then remove the cover over the mirror adjuster itself and pop off the doorcard!All that to get at 1 measily 10mm bolt lol! :thumbsup:
