1999 Toyota Celica 1.8sr Valve Clearances
kylezx7r
im changing a head gasket and valve stem oil seals on my 1999 toyota celica 1.8sr however im not 100% sure on setting the valve clearance on that motor. its the 7AFE engine. im not sure if they are shimmed or weather the cam followers are hydraulic in which case they will not need to be set. if anyone could shine light on this i would much apprieciate it or if anyone can tell me where ill get this info.
my e-mail address is kylezx7r@aol.com
thank you
