Calipers
hotrod007
Hi is there anyone who can tell me how to get the top pin or bolt, off of the front caliper on my ST185. :unsure:
do you mean to get the caliper of its mounting?
i recently changed the discs on my 185 and to get the caliper off just used normal socket set canit remember the size but i remember it being extremely tight so just spray it with WD40 or sumthing similar leave it for a bit then unscrew with the strength of a bear
It's 12mm iirc. Use a good quality 3/8 6 sided or flank drive socket with a 18 inch breaker bar. Makes life so much easier. When you do them back up don't over tighten them. Use a torque wrench. :thumbsup:
ok thanks guys the caliper moves up and down but not side to side think its ceased.
