Engine Noise
smo
At idle my 1.0L GLS 1999 Yaris seems very noisey. Cold start is fine however, as soon as it's up to temp it becomes unstable at idle. There is a high pitched hissing noise at idle which goes when you apply sum throttle.Also when going up a gear I tend to get the noise from the engine you would get if you were in a to high gear for that speed. Could it possibly be an air leak?
Any comments would be greatly appreciated
smo
Does sound like an air leak somewhere. First thing I'd do is check the hoses going into the intake manifold for splits
