Sevic In Dash Dvd Player
Lia TOC
:angry:
Hi again,
Well i got my wheels, new pics up soon.
And I went to get my new head unit... It doesnt fit!!!!
its too big :angry:
I tried fitting it into the bit at the bottom at my dash where the custom ones meant to fit. But its too big to fit in.
So I now need a new head unit... any ideas? Im wanting to spend around £250 and it has to have mp3.
Ive also been told that if i got a DVD unit that the sound quality would be better.
is this true|?
I presume you're fitting it with the new fascias (The toyota one), and not in the coin tray?
i have the old kenwood in atm. which i put in
i sized it up and the plastic attached to the dash gets in the way.
Yeah this is the case with a few DVD players with a larger front panel then DIN size. It should fit fine if you relocate it to a fascia so it isn't below the existing tape player! And for £250 u can get a lot of HU!!! Also a DVD HU alone wont sound better but you could fit more songs of a higher quality on it. However if the Unit itself isn't as good as a normal MP3 Cd HU it wont automatically be better quality!
Well i have two options for you!
http://www.halfords.com/webapp/wcs/stores/...ategoryrn_31445
This is the one i have and sounds immense!
or if you really want dvd player
Sounds ok actually but no were near as good as alpine! you will need to get a toyota rav 4 fascia for this one tho!
Hope this helps!
thanks for the advise - but really not sure what u mean about the fasica thing.
you mean i could put it in the tape player bit instead?
how?
Basically you buy a part that replces the tape player from toyota and it takes out old tape player and replaces it with two holes a coin tray and your new HU space! Search for a post from ryan1985 about what parts u need!
Yeah with the fascia's (RAV4 insert which is an autoleads part bought from any car audio shop and then the outer bit is a toyota part) it should look like this
(Courtesy of Ryan1985 (hope ya don't mind mate!))
If you do a search you can find out all the part numbers etc. :thumbsup: May work out cheaper and less hassle then forking out again...and it looks better :P
Ryans got a quality taste in music :P
Shut it you tart! :P
No worries Woody! :thumbsup:
