CELICA 2.0GT import
ROYSNOSE
Please help.
I have a 94 2.0GT import and I need to know what oil to use in the auto gearbox?
The car won`t change into top gear untill it warms up a little (about 5 miles).
ooooh er misses ME HOPE`S IT`S JUST THE WRONG OIL........
Thanks now for any replies....
Don't Toyota recommend you use their own oil? I know most manufacturers would, but if you use Toyota transmission fluid then at least you have peace of mind :P
  • 3 months later...
Hi... New to the Celica myself. I too have bought an 94' Celica GT Import and I too have the same problem where it change up to top gear untill it the engine gets warm. Is this normal or could there be an underlying problem with the auto box.
hi there
i had a new clutch put in by toyota in my 96 gt import and
the oil they put in the gearbox was there own gear oil which was a 75w90.
But for a auto box they use a dexron type 2 automatic transmission fluid. (ATF) duckhams uni-matic. it might be the selector cables need to be adjusted
Please help.
My imported 94 Curren 2.0 auto also does this, I think its's just an inherent problem, if indeed it is a problem, please let me know if you find out any different though :D
Guest Josef
I have a 2.0GT CElica st202 import but it is manual. However I also own a RAV4 which is auto and the manual says that the car will not shift in top gear before it is in normal working temperature... So it is not a problem it is the norm...
