Hi All,
When I turn on my head lights the right turn signal starts blinking. I would like to see the fuse but don't know the fuse box location. Please help. Thanks
Carolla 1998 LE
Knowlson,
There are three fuse boxex in the engine compartment, but none of them has turn signal fuse. (The boxes are labeled for each fuse and none of them are marked as Turn signal)
I have also checked the kick pannel on driver side but it does not have any fuses. Thanks
OK
what about passenger side? also have you checked the flasher relay on the drivers side?
I did check the passenger side but fuses are not there either.
I'm not sure what is a flasher relay and how to check it. Please elaborate.. Thanks
flasher unit on drivers side
its the big block on the right
and the flasher unit
its the left hand unit
Thanks. I'll look for it. What should I be checking?
just make sure alll the connectors are in. also if you can check the voltage to make sure there is no short if u put the hazards on it shoudl be 12v. if all thats fie I would start checking the lights out make sure the connectors for them are fine
