Anyone know maximum size wheel without modification for aygo black?
i think max is 16" with a 195/40/16 tyre
i have 15" alloys on with 195/45/15's but its caused me all sorts of problems. If you dont plan on getting it lowered or carrying much weight then you'll be fine.
But if not then i put a post further down with sum pics of a little screw that sticks out in the wheel arch which will shred your tyre if you dont have it removed.
I've seen an Aygo with 17" without modifications :yes:
The diameter of the rim is not the issue as long as you keep
the total diameter of the wheel the same as the originals.
It's the fact that the lower profile tyres and wheeld are usually
much wider than the standard 155's which can cause
clearance issues on the mudguards and the suspension.
What width were those 17's???
I guess 195/17/35 :)
It must have looked awful
dont think u can get 17;s in 195 probs be a 205/35/17
