Fifth Gear Fixed
Methuze
Hi all,
Got the car back today after the fifth gear started popping out whilst driving. Thought it would be of interest to all. The gearbox didn't have to come out, there is apparently a access panel for the fifth gear on the gearbox where you can pull the gears out from.
You have to look carefully at the images to see the wear but its there alright. When the two cogs are together the gears simply slide apart and the gear pops out.
The three gears that have been replaced.
Close up of the internal gears.
And the outer ring that meshes with the previous image. You can see the wear on the right side of the teeth here.
Main thing is its all fixed now, juts got the MOT to do now. Cars eh!
  • 5 months later...
Hi there,
Thanks for the post. I am interested in the images but they are not available to see or download. Could you try to post em again or PM me.
I think I am heading down the same road. I would be interested to see what needs replacing since my brother in law works in a garage and could be of help.
Thanks,
Do you get any warranty on the Toyota Avensis Gearboxes? - it appears a lot of people have complained so far.
