Starterbutton S2000
G6-R
I bought my self a little present in the States from eBay , its a Honda S2000 starterbutton .
My mate has done the electric wiring for it and now she works :thumbsup:
I turn the key and than i PUSH the RED BUTTON ;) and than she runs
nice1 jo, i see u put it on the cigarette slot. Looks gr8 :thumbsup:
Not at all , you have to make the hole where the cigaretlighter sits Bigger , than you use the wiring from the cigaretlighter and a RELAIS than you have to find the wire that you need to run the Startermotor connect this one olso to the Relais when you do it yourself you need a couple of hours for it all
Looks cracking that does.
Are you still able to use the key ignition as normal?
YEP :thumbsup:
