Yaris Paint Code
viperroom_112
hi guys , could anyone tell me the factory paint code for the eclipse black yaris , or where i could find it . Cheers David
it will either be on the drivers side of the engine bay at the back on the metal plate.
Or somewhere on the passenger door on a black sticker.
Not sure if they are 2 numbers and a letter or 2 letters and a number.
It'll be a short code with 2 numbers & a letter (my old car's paint code was 8M6), I found it on the plate in the engine bay as mentioned above
If in doubt, give your local Toyota a ring, all they need is your reg and they will tell you over the phone, i had to look for mine a while back but just wanted to double check with them that i was correct.
