Yaris And T Sport Springs
choading
Believe they are the same dude but OMP also have different springs for T sport and Normal yaros which is weird maybe its just lowering levels?
It all depends, OMP make shorter Tsport ones than normal yaris ones as the Tsport's chassis is built 25mm-ish lower than normal yaris! A well made spring company you would hope would also accomodate for the change in weight between a Tsport and a 1 litre (around 100kg difference). However i don't think you would have any noticeable problems and fitment should be fine. However i dont think pi springs are very highly rated as a good quality spring and are known to be bouncy etc. :thumbsup:
