Rear Fogs
TCGT
hi, whilst preparing the Celica (182) import for it's test I tried the rear sidelights.
On the nearside I got two lights and on the off I had one (the outside one).
As it was odd I took the bulb from the inner "sidelight" so I had just two lights on , outer near and outer off.
The bulb I removed was a twin filament bulb with matching socket which had been "worked on " as it has taped connections.
The car failed because it had no rear fog.
Hope you followed that, my question is has the 182 got a Side/foglight combined either side of the number plate as standard as the two sockets I have are double filament and look added.
cheers
I'll be interested in the replies to this as I don't have any side lights working on mine.. You click the lever forward, before the lights pop up and I should have sides come on but there is nothing... Forward one more and the lights pop up and I have the main headlights small bulbs on, then once more and I have dipped or mains.. But above the indicators I have two (running?) lights and nothing I can do will make them work... My fogs are seperate from my back lights though...
Cris
Cris
Hi ,
I think I've found the answer here
JDM Fogs
My inner side lights have been converted to side/fogs with the substitution of a single filament holder for a double one.
cheers
