:ffs: How does one gain access to rear window? Motor still works but window is slipping and will not raise or lower without manual help.
Ihad this problem ,removed the carpet to reveal panel screwsand the removedthe panel,then spray the rubber slidesand glass with wd 40 ,`then turned the key switch and manualyhelp the window up and down a few times then it worked on its own....magic!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
