Cold Air Feed
kimi
Hiya :D
Does anyone know where i can get a cold air feed from ?
not pipercross as that sticks out to far.
I want it to sit flush in the bumper, so it looks stealth.
Its not for the yaris, but i guess alot of you guys have them,so thought
you could point me in the direction of one .
kimi xx
Quite alot of people have DIY jobs on here, either piping which is meant for something else of custom made steel piping designed for car.
Sorry cant help very much!
I was going to use some heater ducting from Halfords until I realised my Envy kit sat right behind the foglight, so I removed that instead.
Think its about £4.99 for it and its very flexible and can be cut to size. :)
Bet you can spray it black aswell if you want it to look even more stealth rather than having a tinfoil look behind your bumper.
Its not the ducting i'm looking for guys,
its the shiny end bit :rolleyes: hopefully in black but normally red or blue
so the spray can will have to come out!
I know some people use speaker bass ports to end they're ducting? They are fluted at the end so give that ram effect i guess? If not a demontweeks catalogue should have a few under there brake ducting section!
Yep, that's Lee's (knightrider), the bass port looks spot on, but the only thing is cutting a hole in your bumper :o
