Alarm Internal Sensor Switch
tim5780
hi all, you know the small switch on the forward roof mounted light cluster that switches off the internal sensors for the alarm. how do you know if they have been switched back on? there doesn't appear to be any visual indicator? thanks all
john. hope this helps,when you wish to disarm the interior alarm sensors as you are about to leave the vehicle you have to press the roof top button and exit then set the central locking as normal. you will notice that the internal red alarm light flashes very quiuckly to inicate the sensors have been disarmed ,when you come to unlock the car the whole system resets itself back to normal so if you want the sensors disarming then follow the whole procedure over again.
good fun or what. :thumbsup:
