Earthing An Amp In The Boot
forde
I know a lot of you guys have subs, im installing mine tomorrow and cant see anywhere particularly obvious to earth it to in the boot.
Suggestions?
Cheers... :thumbsup:
the suspention 1 worked for you? i cudent get it to work on that mines on the boot hook not the catch if your confused.
Suspension one should deffo work as it's where the lights are earthed (if you're thinking of the right place! Pop off that plastic cover and look down the side of the rear strut tower (Guess it's called that at the rear aswell :P) and there is a bolt through it with another cable going to it :thumbsup: You have to bend the plastic back quite a bit tbh!
got some audio guy to do mine, he lifted up the seats n put it somewhere under there...if that helps :-S lol
This might sound like a stupid way of doing it, but i actually attached it to the spare wheel screw. Still works,.. so shudnt be a problem. But if theres a better place, I would rather try that. I only put it there coz i couldnt find any where else to attach it to, and i couldnt be bothered to mess about outside in the cold anymore :P
^ my cousins got it on his car like that, should be alright, i think its the seat belt thing under the seats mines on...
