Hi - I have a Toyota Lucida 1995 diesel and recently the oil change light came on. I checked the oil which was low so topped it up but it still stays on constantly. Can anyone help??
The light is simply a mileage related warning. It just means it is time to change the oil.
It should be changed every 3000 miles.
The light can be cancelled by removing the little rubber plug on the speedo face and pushing in the little button on the speedo with something like a skewer with the ignition switched on.
