Help! Headlight Needed
silver surfer
Im having problems with my Offside headllight unit for my 1992 Levin Ae101.
It is constantly misted up :unsure: , i have tried several times to fix the problem,
i have completely taped up the rim, there are no holes that i can find.
My MOT is in 16 days and it will fail. I would like to get another headlight unit, does anyone know where i can get one before my MOT is due.
Your help will be greatly appreciated.
not sure on sourcing one (you could try fensport),but if you tka it out ,remove the bulb and use a hairdrier on it before the test it should pass as long as the reflector isnt coroded
on a similar subject, i've got a nasty stonechip in mine, similar to one you'd get on your windscreen. does anyone know if it will fail on that, as it goes for an MOT tomorrow?
silver surfer, if you need to replace it, just do a search for japanese parts - there'll be a load of specialists. :thumbsup:
