Yaris 1.3 Vvti And Daihatsu Yvr Turbo
Brolly
I've read somewhere that the Yaris 1.3 vvti engine and the Daihatsu YVR turbo are very simiral....
Are so similar that some parta may fit (plug and use) from one engine to an other is that the truthe
I've heard that the iron manifold and pistons can be fitted strate away to a 1.3 vvti engine is that ture ?
From reading previous post's on here that the engines may be the same but the internals are different. So a search and it should bring up a fair few results
ok ok i what more bhp from my engine.... i found that the Sirion engine has a very similar emgine but with different crankshaft....
i've also found that the YVR turbo engine is also simila and that if one fits il gaskit, pistons, mainfold and turbo would add more power to the engine and remains save from blowing up the engine is that right ??
can someone onferm this... or has a fist hand experiens of these ???
