Connects2 Ipod Connection
IanJ
Can anyone who's fitted a Connects2 iPod connection to a 2005 Avensis give me some tips on where they mounted the two boxes please?
I know how to remove the head unit and guess the connection is just a case of removing the existing plug and replacing it with the new one.
Ideally I'd like to have just the cable coming into the glove box. So I'd like to mount the boxes behind the radio without them rattling around.
Help!
Help!
have a look at this link http://toyotaownersclub.com/forums/index.php?showtopic=62534
i just used pull ties to attach it to the wire loom behind glove box
OK, thanks. Did you have two boxes connected by red and white AV leads?
no not at all just a box
the lead plugs into cd changer
if you have a cd changer this plugs into the new loom attached to the box
Just to let you all know I've succesfully installed the iPod adaptor now.
I mounted one box behind the glove box high up. The other I decided to leave in the glove box itself, it's only small.
If I decide to remove it at any time now it's just a case of taking out the glove box and disconnecting the two boxes from the wiring loom behind the radio.
