Which Tns Navigation Modules For 2004 Rav
jonnyspin
Hi all.
just bought a 2004 Rav4 d4-d xt4.
it's my 4th toyota after a MR2, Celica, Corolla.
I fancy adding the nav module to the standard head unit.
Which TNS model should I buy from eBay?
What else do I need?
Thanks!
Hi
You can either go for the tns200 cd based or the tns300/310 dvd based(all of europe on 1 disc) dependant on budget.
Either way you will need to check you're head unit has the navi button on it .
You will also need the wiring loom\the ariel & a disc.installation guides can be found at
(http://techdoc.toyota-europe.com/aim_SearchbyCate.asp?mscssid=&vehicle=RAV4&admin=&strkata=0&strGene=0&strCate=0&strAccGroup=0)
I fitted the tns200 it was fairly easy.
You could also look at the full screen double din sat nav system but they are quite expensive,do a search on here for sat nav for more info on these.
regards
Chris
