Speed Limiter
jjerry
Hi as some of you will know I am new to toyota surpa land. I own a 2.0 tt targa. I am trying to find some info about speed limiter as the one time i got to drive it so far the car seemed to cut out at 120 as i backed off it came to life again. I don't have a boost gauge just a green light on dash in yhe middle of the speedo.
Any ideas gratefully recieved. :help:
Jerry.
(hpefully steering rack rebuild kit will arrive from the land of the rising sun this week and we'll get her back on the road. :thumbsup:
Yup sounds like the speed limiter to me!!!
To get rid you need a speed limit defeneser, I also thing that Apexi RSM will remove the speed limit!!!
If you get a geared km/mph speedo converter, it raises the speed limiter to 180 mph :D which should me more then enough :thumbsup:
yeah but it screws up the cars entire speed signal, causing other problems.
shame on you charlie :wacko:
Name one thing that will get screwed up in car with no TEMS, no ABS and No PPS Adi ;)
one thing? the autobox :D
besides, its the whole idea of people suggesting that all you do is bung a mechanical converter on the cable and all's well.. it isnt as simple as that. The speed signal is used on a lot of ECU functions.
I thought Jerry's car was manual ;)
I seem to recall it being exactly the same as mine factory spec for spec...
I personally run a UK speedo, keeping the speedo signal un molested, but get past the speed limiter by having a mines ECU... :yes:
For most people a geared converter is eaiser then wiring in a speed limit defenser, and on a 2.0 GT manual it doesn't mess much up either ;)
Nope :thumbsup:
Nope :thumbsup:
do you think mine will how can i tell or find it ?? h reg 7mgte 3.0i manual turbo ???
Go fast enough and see ;)
Or on a more serious note, only the Japanese imports were limited.
SORTED THANX
