hiya i have a hilux pick up 2.4 diesel and it smokes under presure ie towing
is there a common fault that i should look at
thanks flyhigh
Hi
I used to have a Mk3 Hilux which smoked a lot going up hills. This was because I got a mate to 'open up' the fuel pump adjuster to get more power when towing.
A previous owner may have done this with your pickup.
Try turning the pump adjuster screw in about half a turn at a time and see if this helps!
You will loose a bit of power but try to get a happy medium.
Hope this helps.
Tony
Black smoke is normally due to a air to fuel ratio this could be
Faulty injectors normally need reconditioning or new around 100k - 130k
Dirty air filter
Injector pump problems
Turbo problems
Problems within the head, valves clogged or faulty EGR valve
Cheers
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
