Another 4ws Problem
diger191
The warning light for the 4ws came on the other day and found some info on here
about tracing the fault, I connected TC and E1 in the diagnostic box
but the warning light didn't flash or any other light for that matter,
so I can't get a code to narrow it down,I've checked the connection and it was fine, also the sport and 2w rev
indication lights stay one regardless of the button positions, I had a
look at the sensor at the front wheel and was led to belive that it was
a pig to get out, but this one just slipped out but the sensor was
covered in dirt and looked like it had been hit on the end with a
hammer. The front and back wheels both steer in the same direction all
the time even in reverse, I've read this is common when it is a sensor fault. What
I would like to know is, am I doing the diagnostic bit right and if not
how do you do it and also where would I get a sensor and how much are
they? I would be grateful for any help at all.
