Immobiliser Problem After Battery Disconnection
southdowns
Hello all
I'm new to this forum and am hoping someone may be able to help me with a problem.
It's a UK spec 1997 RAV4 Manual. It has two large key fobs but no remote control locking.
Today I completed a timing belt change for which I disconnected the Battery, on re-connecting it it wouldn't start and there was a very quiet clicking sound in exactly the rythm of an alarm going off. It's as though somone has disconnected the alarm siren but the immobiliser has kicked in.
For an experiment I disconnected the Battery put the key in the ignition, turned it all the way to the 'run' position then reconnected the Battery and lo, I urned the key that last little bit and it started perfectly. The only trouble is after I switched it off I was back to square one -ticking sound and won't start until I run the battery trick again.
Any help much appreciated.
Martin
southdowns
Hello all
Today I completed a timing belt change for which I disconnected the battery, on re-connecting it it wouldn't start and there was a very quiet clicking sound in exactly the rythm of an alarm going off. It's as though somone has disconnected the alarm siren but the immobiliser has kicked in.
For an experiment I disconnected the battery put the key in the ignition, turned it all the way to the 'run' position then reconnected the battery and lo, I urned the key that last little bit and it started perfectly. The only trouble is after I switched it off I was back to square one -ticking sound and won't start until I run the battery trick again.
Martin
southdowns
I'm not sure I can help you with this as I am not so familiar with 4.1 or 2 models. I thought that the immobiliser was only operated by recognising the chipped key in the ignition switch pick up. In other words disconnecting the Battery should not have an affect.
Is there an alarm that has been disconnected or had the sounder switched off?
Have you tried both keys?
Regards
hi
just as a matter of interest i have a RAV4 auto 5door 1997
and twice the Battery has been off without any problems
when replaced.
good luck with your problem
marshall
hi
and twice the battery has been off without any problems
when replaced.
marshall
Hi All,
I have the RAV4 auto, I have the same problem, I was away and the Battery went flat, that set the alarm off, the Battery was flat for a month, after recharging the engine would only start if I turned the key then connected the Battery “OR POPPED THE BATTARY LEAD OFF AND ON” a few times, I could hear the relay chatter, the engine only runs for about 10 seconds, question, did you find a solution or where is the immobiliser located?.
Cheers Gene,
:ffs:
Hello all
Martin
southdowns
Hello Martin.
Cheers Gene,
