Corolla 2004 Clock
LesPaulStd
Hello from Spain,
it is the first time I write at the forum. I want to know if anyone could tell me if the clock wich is located in the dash, near the warning lights button, is a separated part or is part of the clima-control and, if is separated, wich is the part number.
I'm guessing you have either a T-Spirit or T-Sport as you describe your dash with climate control.
As far as i can remember you should be able to buy it separately.
If i get time, will rip my dash out and have a look for you, even get few pics if i can for you.
Bing
:thumbsup:
Thanks for your answer.
I don't know which is the correspondence between Spanish models and U.K. ones, but I don't have clima control, only air conditioning and in this case, there is not clock neither the one in the head unit. So, if I change the head unit, I'm going to loose the clock.
Thanks in advance
Is there any document where is detailled the piezes and part numbers of the dash, including the clock?
