Sr Too T Sport
jayj
SR engine is a T sport engine just bored up i believe, well same design anyway.
I dont think it would be worth hassle mate, the 1.5 isnt that much better to be worth the cost and it would be cheaper to get a T sport!
for what it costs a t-sport is cheaper
and it will be slower unless you also change the gearbox, as the gearing ratios are shorter which makes the t-sport faster.
also you will need the wiring and ecu for fueling, also better brakes or discs at the rear to brake better because of the extra power.
you would be better off selling your car and getting a cheap early phase 1 t-sport.
Tsport is a Stroked 1.3 Ad :thumbsup: And yeah just buy a Tsport and carry the bits across as that is less work than full engine work etc! Also Tsport is built 20mm lower to start with to handle better so you wouldn't get that either!
No dont buy a t-sport, play with the sr abit more, getting a t-sport is just the easy answer.
Or of course you could buy a D-4D and give yourself a real challenge...
If your Yaris is an French SR then, quite frankly, you haven't a hope in heck of managing it.
A
You forgot to mention the sensible answer too! :P
