Wheel Width?
Hardy87
Iam right in thinking that when getting new wheels you should stick to 7.5" width? I have seen some wheels i really like but there 8" wide how much of a diffrence if any do people think this will make?
8" will be fine just make sure you get an appropriate offset so you don't have to use spacers. Stock wheels are ET35 however depending on the design of the wheel your after you may need to change that a bit.
Best to checkthe fit to avoid the need to fit spaces to clear the brakes or have the wheels sitting to far out...
