Adding Abs
tyrant_360
Is it possible to add an ABS to a 7th generation corolla(e.g. ae-101,) that didn't come with ABS when it was purchased? Do you need to get a new ECU, calipers if this is possible?
Even if it's possible, I wouldn't think it's worth having it done as it will cost more than the cars worth.
Just up grade the brakes. It should give you a lot more feel. Then ABS isn't so needed, when you can feel whats going on. ABS won't make up for bad brakes either.
Pb
:wacko:
