Help Needed With Verso Wiring
RinkyDinky
Hi Guys, hope someone can help.
I have a 2004 Verso D4D T Spirit with Sat Nav etc.
I have a company who are fitting a Pioneer unit to the car and need to know the following:
What is the colour of the speedo connecting wire which connects to the plug on the back of the dashboard.
We need to know as this is where the pulse connector is to be fitted (we can locate it elsewhere but do not wish to interfere with the car's need for the supply.)
There appears to be only one plug fitted to the back of the dash clocks, so if anyone can let me know which colour would connect to the speedo from this location, i would be grateful.
Thanks :thumbsup:
  • 10 months later...
Hi RinkyDinky,
Here an answer staight from the Neterlands. Since January 10th I drive my brand new Corolla Verso D-4D-CAT (Your UK T180 version) with full-map DVD Navi and I'm very :D :rolleyes: pleased.
Your Wiring problem, I have found out during (lot's of) surfing on the Internet that de ODO signal is the Pink wire in the cable ending in the 24-pole connector.
Surfing on this site, you can search with the search string "TNS600" or "TNS700" also possible solutions, but the Pink Wire seems to bee the one.
Succes,
JosTS180BHp (TS Stands for Tire Shredder)
