Pedals
skyliner34
How the hell do I remove the accelerator pedal?, I've got the clutch and brake rubber off but not the juce pedal.
I've brought some Sparco smart pedal set > Pic
the pedal is one piece plastic, not metal with rubber on, hold sparco pedal on top and drill holes inline and screw on
Just gone out and done it. The clutch and brake pedal was easy. But the accelerator was a pain. The bolts are to short, so I'm gonna go to B&Q or somewhere that sells hex head nuts and bolts, lol.
Looks really neat though :)
Too late for self tapping, I've allready drilled the pedal. If I knew there was no metal under the rubber like the other two I would of probably used self tapping screws. Nevermind, bolts are cheap to buy.
my first rely stated they were plastic, sorry you drilled out too big, you will have to find some nice chrome counter sinc screws so they fit nice and flush
Thanks :), I drilled it before I saw your first reply. The hold is exactly the same diameter as the bolt that came with the pedals. Shouldn’t be too hard to find some chrome counter sunk bolts.
