Yaris Tachometer
Yaris_F
Does anyone know if I can put an analogic tachometer(rpm) in my Yaris? e.g. autometer
I believe it would be usefull because the electronic tachometer(rpm) is a little small and hard to notice it.
Best place to fit it is on the steering wheel column?
It would look pretty good an analoge tachometer with the electronic speedometer.
an tacho like that will normally run from a pulse coming from the ingnition circuit
dunno if the yaris does it all by the use of the ecu.
best enquire with the manufacturer for the best answer
You can do it - I had to pick up and RPM pulse from the enginer for my IntelliStart - I will have a look and see what wiring I used.
Cheers.
Steve.
