Fitting Dump Valve
boghopper
hello again, would anyone with a dump valve fitted be kind enough to post up some pics of their engine bay so i can see where i should be connecting my dump valve please?
i have fitting instructions from bailey motorsport, but they are just written and no pics.
i think i am going in the right direction but ain`t 100% certain and dont wanna knacker anything thru my stupidity.
thanx in advance
glenn
which model have you got ? (ST-185 or ST-205)
dawesy it`s an st205, but i got it sorted now fella, i have another prob thats come up tho if you have any advice, when the revs get to 4500rpm-5000rpm theres a hesitation from the engine pulling, it results in quite a jolt doesn`t happen evreytime, but does most times. any ideas/advice ?
cheers
glenn
unless youve got a garret gt3540 in there :lol: it might be somthing in the ignition system. might be worth changing the Plugs (NGK platinum grade 6 or 7 only dont put cheap plugs in) leads, dizzy cap and rotor arm.
the leads cap and arm are best got from john at toyota celica breakers (google it) as he gets the genuine parts a lot cheaper than the dealers
i`ve got a local tuning company coming out wednesday to give it a full diagnostic check and see if he can find the problem with it. :thumbsup:
