Removing A Dump Valve
chrisE
hi just took the step from st202 to a st185 yesterday an lovin it so far.
just wondering what i need replace wen remoing the dump valve,
i already have a blankin plug for the samco hose, but what do i need to blank the outlet that the thinner pipe comes from the inlet manifold.
cheers chris
cheers chris
What does the thinner pipe(Vaccum pipe) attach to. If it's tee'd into another vaccum pipe simply remove the t-point and replace with a joiner to connect the original hose back together.
If it leads directly back to a port on the manifold just cut a short length of it and fit a suitably sized bolt in the open end and secure with a couple of hose clamps.
