Tyres
GreyRacer
I've just run in my new set of Vredestein Sportrac 3s. I cannot recommend them highly enough if you are still on normal sized rubber. This is my 2nd T and 5 years of driving them over 77,000 miles. Iv'e been on Bridgestones and Pilots which by far were the worst. The Sportrac 3's are quite simply amazing. I run at 36psi all round which I feel is a good compromise for stiffness and noise. The front is much tighter and I feel a better response through the steering wheel than any rubber which has been on before. Breaking has improved. In the wet grip is sensational and you can throw the car around with confidence. The TC and ESP do not engage quite so early. Only down side is petrol consumption which is slightly worse.
thanks i keep it in mind but for now i will stick with toyo t1r .
you pump 36psi ? :o what size are your tyres ?.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
