Yaris 2nz-fe Crank Pulley
abdielhiram
Hi guys
I´m wondering if it`s possible or someone of you did the Crank Pulley swap for a Yaris 2NZ-FE engine which is a 1300 cc. I know somebody who has a 1NZ-FE 1500 cc he changed it, but that same pulley will work on my engine? I´m aware of all the warnings about the pulley swap, but just want to know if that same pulley will fit my ride engine.
Will wait for comments.
2NZ-FE is the SR which has the same engine as the 1.5 so it should fit.
if you know the person who fitted it to his 1.5 use his old one to check fitment before buying
Perrin pulley fitted fine on mine!
The only probem is that the crankshaft bolt is properly tight, so you need good tools, a breaker bar, and a screwdriver to jam the pulley to stop it turning. You also need to do it back up FT.
I needed none of this, I had an earpl!
Oh, it's a s**t-hot bit of kit too. Coupled with sports-cat/de-cat and manifold, the reduction in inertia is very good especially on the motor-way, throttle response is much improved.
