Compressor Red Line
lethal89
Hey people has any1 else's compressor hit a limiter under 6000RPM when cold or do i have a problem????
when cold the engine should limit a lot lower than normal - to protect itself.
my CTS limits itself about 1000 below normal when cold
my pre feace-lift chokes at about 5800 when it's cold so I'd say the compressor should be the same.
my compressor seems to have 2 stages When you first get in and drive off it feels very flat almost like a 1L.
after about 2 minutes of driving this stops. You can often notice this when you have about 3000 revs in 3rd and hold it. all of a sudden it eases and wants to go.
At this point you will on;y get up to about 6000rpm. After about another couple of minutes you will start being able to hit lift and take the car to the 8000rpm mark.
