Wheel Trouble!
Hardy87
Iam having real difficulty finding a set of wheels i like and that will fit. Iam after a set of INOVIT ST V1's but have been told they will only fit using 20mm spacers. Does fitting the spacer mess up the handling of the car, or have any other negative affects? And if so any suggestions for wheels on a black ST205.
20 mm should be fine but be sure you get propper spacers that bolt to your hub using the original studs and then have extra studs built in for the wheel.
brings the wheel out to the arch nicely.
check out GT4OC.net for wheel info as IIRC there is a list of wheels on there somwhere that will fit
