Gearbox Oil
brad
i got a 4th gen celica.. aint got a manual as of yet as got more important things to spend it on... just wonderin if yous know where you put the gearbox oil in.. and where u take it out haha.. thanks
if you go to the front of the car look down on the right hand side of the engine just under the Battery on the front of the gear box casing you should see a large plug it can be a large hex nut or a allen head type plug this is the filler plug for gear box oil. the plug for empting it is under the car directly in line with the front plug it will be the same type plug. this is for a manual gearbox. ps be carefull when opening the filler plug as it opens up towards the Battery tray as your hand can slip when it opens and get sliced.
and youl be needing some DexronII gear oil :thumbsup:
before i go, id say use a long extension bar that reaches above the Battery...save sliced fingers n all that lol :D
