17in Split Rims
PaulT
I've recently changed my Soarer to Toyota Soop mk4 alloys, so have an aftermarket set of split rims for sale: 17in, 8in wide fronts, 9.5in rear, pcd 114.3 four- and five-stud, offset 45. Basically the same size as the uk Supra 17s.
Tyres are Falken ZE512 which are durable but only medium grip I would say. Still plenty of tread left on these puppies, but see below. Front 235/45/17, rear 255/40/17.
The wheels come with quite a nice set of 20 custom lightweight nuts including locking nuts and key.
There's a good chance these wheels will fit over Supra 4-pot calipers, but you would need to try them to be sure.
Bad points:
* I only have three centre caps due to a thieving chav.
* The previous owner seems to have been unable to avoid driving into kerbs. Some scratches but no buckles or dents. Would need a refurb to be show standard.
* The driver's side front tyre seems to be losing a couple of psi per month. I'm guessing it was put on by a muppet and hasn't been sealed properly.
* One of the rears has a screw embedded in the tread. I haven't tried to remove it but it's possible that a repair may be needed.
Thinking of offers around £300 for the lot.
Paul.
