Arb's
cfc1
The car went in to Automotive Services in Dunfermline today and got some new bars fitted.
Prices...
BTR81Z - Front swaybar £135 (incl VAT)
BTR84Z - Rear swaybar £135
W0007 - universal swaybar link pack £8
KCA414 - Adjustable camber bolt kit 14mm £43
KCA415 - Adjustable camber bolt kit 15mm £46
KLC40/195 - Link kit universal ball joint 195/122MM £93
Altogether (with Poly bushes) just under £500 fully fitted with the full geometrics set for a neutral setup
Haven't much of a play yet.. but have been told it will be a lot better in the dry.. but... carefully does it in the wet... If I can get pics up I will do it tommorow ;)
Thats great news, one of the best mods you can do to a car. are these uprated parts you've quoted? if so, what make? my mk1 will be going there soon to get setup properly for the track.
cheers.
Yep.. all uprated parts.. Whiteline. :thumbsup:
Here are some piccies....
Front bar and droplink bush kit.
Rear bar, camber bolt kit and droplinks.
Rear droplinks and bar.
Better than it did before :P which was pretty good anyway.. :D
