lol nearly 2 years I have had the Aygo and only today realised where the water jet for the rear screen comes out - anyone else noticed this unusual design ?
A nozzle in the 3rd bbrakelight isn't that uncommon!
The fact that it can't be adjusted is... I wouldn't even
call it a jet, more like a mini-mini-mini waterfall...
Yes, but it also looks like it has been designed around LHD cars. Seems to be on the wrong side for RHD?, or am I wrong in thinking they change the side of the wiper motor????? and also the rear window?? :unsure:
Talking of mini waterfalls, i nearly had a panic one sunny day when half a pint of an unknown liquid poured out near the front wheel arches. Turns out it was water from the drainage channels in the front doors. I'd been to the carwash, which sprayed water into the gaps between the glass.
I must point out that the Aygo's Shell is galvanised, so rust is a non-issue. Especially with the standard anti-perforation 12 year warranty
I think you're right annd I can't blame the manufactors;
this car is aimed at Europe and except for the UK and Ireland
Europeans all drive on the right side of the road in LHD cars.
If they'd have had to adapt the rear screen for RHD it'd be
more expensive as the hole for the wiper is off-center...
Look at the glovebox lid; on mainland Europe it's about €40
in the UK it's ±£40 which is about 1,5 times more expensive as
the market for those is less. Supply and Demand applies here...
