St185 Running Rough
Cexy_Ratt
Hey , just done my headgasket, what a lovely peice of equipment the GT4 is to work on, anyways its all up and running again. No water leaks etc.. but i just seems to be idling a little funny, seems to go up and down sometimes very low, but picks itself up again.
Just wondering if anyone can suggst anything to look at, done the usuall checks but the idle still seems iratic, cheers
[sounds like you might have a pipe off /on wrong or plug mabe a air leak
thanks for the reply, was over looking some photos i took on my camera phone, and have spotted a little vac pipe which goes to the cold starter area of the throttle body which has defo not been put back on, so must be down to that, will pop it back on tonight.
Picks up soo much better with the ST205 turbo on aswell, got an FCD for it aswell, got a 2mm TRD HG, XS power downpipe, full S/S system , decent air filter, and a ball and spring relief valve, so i should be all right to run 1.1 bar i would thing
